Surface Dock Firmware Updater won't install - Failed to install SurfaceBaseFwUpdateDriver.dll
2018-02-02T13:12:27+00:00
Hi
I'm trying to install a firmware update for the Surface Dock I am using connected to my (first generation) Surface Book.
Primarily I'm trying to do this so I can charge my iPhone from the Surface Dock without having the connection repeatedly connect and drop.
I am running Windows 10 (Creator's edition, up to date as of 2nd Feb 2018) and trying to install:
Surface_Dock_Updater_v2.12.136.0.msi
During the installation process I get the following message.
Failed to install SurfaceBaseFwUpdateDriver.dll. Aborting installation.
Any ideas?
Regards
Jonathan
    2018-02-03T04:02:53+00:00
    For us to assist you, can you confirm the following information:
    • Is this the first you have encountered this issue?
    • Have you tried to first check for and install the update using Windows update while Surface Dock is connected to your Surface Book?
    • Have you also tried re-downloading the Surface Dock Updater, then install it to your device?
    For now, you can also force a shut down and restart your device, then try it again.
    Regards.
    2018-02-12T13:24:21+00:00
    I am also having this problem. I have already checked that I am current with Windows Updates, and I have tried downloading the file 3 times.
    2018-02-12T18:57:47+00:00
    Are you also getting the same error when you try to download Surface_Dock_Updater_v2.12.136.0.msi?
    2018-02-14T00:18:36+00:00
    Yep. Same problem.
    2018-02-15T13:29:17+00:00
    Was the Surface Book connected to the Surface Dock when you tried to install the program?
