Surface Laptop # Bluetooth drops out intermittently
2020-01-07T21:57:31+00:00
I have a Surface Laptop 3 and im using the Microsoft ARC Mouse and Microsoft Designer Keyboard
The Bluetooth connection to both these devices drops out intermittenly for around 10 seconds
When it reconnects the Bluetooth icon appears in the icon tray
This happens a few times an hour and is very frustrating.
I have tried reinstalling all the bluetooth drivers which has not helped.
I have also tried this solution offered to another user whoch hasnt helped either.
                 While the mouse and keyboard is connected/paired, open Device Manager
Expand Human Interface Devices
Double-click on Bluetooth Low Energy GATT compliant HID device, select Power Management tab above. Uncheck the box for "Allow the computer to turn off this device to save power" then click OK. If you have multiple Bluetooth Low Energy GATT driver, please do this on all of them.
Restart Surface
Are their any other solutions?
Surface | Surface Laptop | Power and battery
    2020-10-06T00:22:31+00:00
    If all of the surfaces have same problem... Is it not a Bluetooth hardware problem?
     I thought my Qualcomm was the problem, but Intel Bluetooth is also the problem?
     I'm using a Surface Laptop 3, and I swapped it for a new one three times.  It's the same problem. haha
    2020-10-10T12:44:56+00:00
    Having the exact same issue over here with slp3. My headphones just stopped randomly a few months ago and ever since my bluetooth was broken.
    Lets just all sell our the Surface products and buy Macbooks. They seem do their stuff much better at apple.
    2020-10-12T15:00:19+00:00
    Good Morning,
    The issue is not a Surface issue but a Windows 10 release 2004 update issue with power management. Do some research on that and you will see the fix.
    2020-10-13T01:16:49+00:00
    Thanks Chuck. Which month 2004 update had the problem?
    How did you get it fixed?
    2020-10-13T01:52:03+00:00
    Sorry I didnt give you enough information. From what i have read it was a windows 10 update this summer and i believe the main number of the update was 2004.
