Surface Laptop # Bluetooth drops out intermittently
2020-01-07T21:57:31+00:00
I have a Surface Laptop 3 and im using the Microsoft ARC Mouse and Microsoft Designer Keyboard
The Bluetooth connection to both these devices drops out intermittenly for around 10 seconds
When it reconnects the Bluetooth icon appears in the icon tray
This happens a few times an hour and is very frustrating.
I have tried reinstalling all the bluetooth drivers which has not helped.
I have also tried this solution offered to another user whoch hasnt helped either.
                 While the mouse and keyboard is connected/paired, open Device Manager
Expand Human Interface Devices
Double-click on Bluetooth Low Energy GATT compliant HID device, select Power Management tab above. Uncheck the box for "Allow the computer to turn off this device to save power" then click OK. If you have multiple Bluetooth Low Energy GATT driver, please do this on all of them.
Restart Surface
Are their any other solutions?
Surface | Surface Laptop | Power and battery
    2020-09-15T07:27:58+00:00
    Thank you for the answer. The download that you advised did not solve my problem.
    I did download it. Started the download, after a few seconds the update stopped because the update was not for my surface laptop 3
    So still got the problem of my bluetooth mouse, very expensive MS Mouse, dropping still.
    2020-09-15T12:00:42+00:00
    Ty for answer :)
    The firmware does not support Korean, but I will try.
    I'll share it when i get a good result.
    2020-09-16T00:59:23+00:00
    I am having the same problem with my Surface pro x. The bluetooth connection drops intermittently. I've tried multiple keyboards and mice. All work fine with other devices and all have the same issue when used on the Pro X. It is a problem with the pro x or windows 10 not the mice and keyboards. It is very frustrating.
    2020-09-29T09:32:15+00:00
    2020-09-29T09:44:50+00:00
    It hasn't been solved. I still have problems. It seems that the pro x users suffer the same problem.
    any Microsoft staff here?
