Surface Pro 7 camera doesn't work and light always on until reboot
2020-05-11T05:55:28+00:00
Hello! I have Surface Pro 7 i3 4/128 Gb. Camera works several times for Windows Hello and then stops, camera light always on until reboot. I have all updates.
I tried:
  1. uninstall camera in Device Manager;
  2. check and uncheck camera in UEFI;
  3. fresh start and reset;
  4. reinstall Windows with MediaCreationTool1909.
The last method helped me for a week, camera light stopped turns on for Windows Hello (only IR camera turned on) and camera worked. Now camera turns on again and stops after 2-10 times. How to fix it?
Surface | Surface Pro | Sound and camera
    2020-10-05T19:29:26+00:00
    Same, I have two i3s both have this issue.  I've disabled "Windows Hello" face login, and that appears to be a remedy for now.  But having face login was a big selling point of these devices.
    2020-10-05T19:32:28+00:00
    Interesting.  So, everyone with this problem:  Do we all have i3s?
    Now considering upgrading to i5 just to avoid this issue!!
    2020-10-05T19:36:54+00:00
    I was thinking about disabling windows hello as well but occassionally have trouble with the rear facing camera too. This is so very disappointing. not sure a warranty replacement would solve anything if this is an i3 issue.
    2020-10-05T19:42:39+00:00
    My i5 is fine, it’s just the i3. It doesn’t seem this would have been difficult to identify when releasing the product with the i3 processor.
    I’ve now been waiting for tech support for 1 hour, 4 minutes and researching while I wait. I’m outside of my return window now so have to get some kind of resolution. Restarting when I want to use the camera is not acceptable. and the blue screens aren’t cool either.
    2020-10-06T02:18:51+00:00
    For me it is happening on an i5 when the processor is highly utilized. I suspect it happens more on i3 because the processor gets overloaded easier.
