There is no GPS on the Surface. It uses location services based on the internet connection.
Does Microsoft Surface have GPS?
Simple question, cannot find the answer. A couple of websites states that GPS is there, however I find nothing on www.surface.com. The website that state that GPS is there have said that since june and I don't know how they would know?
Surface | Other
As it's a WiFi only device, there is no GPS, but it does have location services as part of the operating system.
Surface for Windows RT does not support an external GPS device such as the one you refer to.
Surface for Windows RT can look up your location based on WiFi signals in your vicinity, as long as the Surface is also Internet-connected. Apps such as Maps or Weather, or web sites through Internet Explorer, can use this information.
Hope this helps
Hello Myron,
Surface RT does not have GPS, however it does have Location Services which allows certain programs to know your location based on IP address.
Was there a specific app you needed to use with GPS?
Best regards.
Another thread about GPS with Surface.
Hope this helps.
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle <- Mark Twain said it right!
115 additional answers
2012-10-25T16:29:53+00:00 I too find it disappointing. No dedicated GPS receiver is a deal breaker for me. I want the ability to use augmented reality apps, I want to be able to use other apps that are location aware too. Maybe even geocaching. Using Wi-Fi to determine locations will be very inaccurate and I won't be on Wi-Fi all the time when I'm walking around somewhere especially in the field. These things need to have everything the phone has minus maybe the actual phone part (although why not throw that in as an option too). NFC, GPS, Compass, Accelerometer...etc. As attractive as the tablets are, I won't be buying one that's missing something as basic as GPS. Serious bummer Microsoft. I'm hoping some of the other Windows 8 tablets will have built in GPS support.
