Does Microsoft Surface have GPS?
2012-10-16T16:40:26+00:00
Simple question, cannot find the answer.  A couple of websites states that GPS is there, however I find nothing on www.surface.com.  The website that state that GPS is there have said that since june and I don't know how they would know?
Surface | Other
2012-12-12T16:23:17+00:00
There is no GPS on the Surface. It uses location services based on the internet connection.
btbt 11,841 Reputation points
2012-10-16T18:47:26+00:00
As it's a WiFi only device, there is no GPS, but it does have location services as part of the operating system.
2012-12-26T22:54:36+00:00
Surface for Windows RT does not support an external GPS device such as the one you refer to.
Surface for Windows RT can look up your location based on WiFi signals in your vicinity, as long as the Surface is also Internet-connected.  Apps such as Maps or Weather, or web sites through Internet Explorer, can use this information.
Hope this helps
2013-04-02T19:11:00+00:00
Hello Myron,
Surface RT does not have GPS, however it does have Location Services which allows certain programs to know your location based on IP address.
Was there a specific app you needed to use with GPS?
Best regards.
115 additional answers
    2012-10-24T13:20:06+00:00
    There are many reasons I would have preferred to use the Surface instead.  Maybe not the RT, but definitely the Pro as I have a distinct need to run Intel based Windows software.  But this GPS thing is a killer and will put many people off.  I will most probably just stick to my current setup of 3 devices (Android phone for phone calls and as in-car hotspot, Nexus 7 tablet for internet, music, and navigation, and Windows 7 portable to run my software).
    Looks like Microsoft has some serious thinking to do, at least for the truly mobile generation.
