WHEW-HEW! Thank you so much.
Surface Camera too dark
The front camera on my Windows 10 Surface Pro 3 was too dark in Zoom (and in the Camera app). There are many folks asking how to adjust the brightness, but none of the answers in the posts I found work and all the posts were closed.
I discovered how to adjust the brightness:
- Open the camera app. (Home, Camera)
- Click on Settings in the upper left corner.
- Under Camera, Pro Mode, Show advanced controls for photos and videos - click to "On".
- On the right side of the window, select the video camera icon.
- A little circle with a slash through it and a number below it will appear on the left side of the window.
Click on this icon and a brightness slider bar will appear. Adjust the brightness to what you want.
- Close the camera app.
- Open Zoom and the new camera brightness should be in effect there, too.
Surface | Surface Pro | Sound and camera
2020-06-24T20:35:11+00:00 -
2020-07-01T21:08:43+00:00 Thank you so much for this!!!
2020-07-08T17:29:32+00:00 THANK YOU!! I had googled "my surface pro 3 camera" is too dark for months and couldn't find anything.. finally added "in Zoom" to my search and found your solution. Thank you!
2020-07-09T21:40:43+00:00 The front camera on my Windows 10 Surface Pro 3 was too dark in Zoom (and in the Camera app). There are many folks asking how to adjust the brightness, but none of the answers in the posts I found work and all the posts were closed.
Wow! I've been trying to figure this out for months.
2020-07-11T00:51:42+00:00 This worked for me!
Thanks so much! I have had 3 lights on my face and i bought a ring light to try fix this - none of that made me any brighter. But your fix did!
