Surface Pro Duo Dual SIM
2019-10-04T17:14:57+00:00
We all saw the unveil of the new Surface devices coming soon, right? I feel like the Surface Duo is tailor made for the on the go business professional who really can get everything done from their Surface Duo with its capabilities. The one thing that I'm sure it's missing is Dual SIM capabilities. What do you think? I have multiple phone numbers and carry two phones, both an iPhone Xs Max and Galaxy Note 8. I'd love to downsize that into 1 and have two SIM's in the Surface Duo.
* Moved from Community Participation Center
Surface | Surface Duo | Mobile connectivity
2020-09-28T16:57:07+00:00
Surface Duo has a physical Nano SIM. AT&T locked SKU will have eSIM disabled while the Open market SKU will support Dual SIM single available (physical SIM and eSIM) – so only one SIM for calls, texts, data can be active at one time.
For more information about switching between SIM data plans see, Set up a mobile data connection on Surface Duo.
52 additional answers
    2021-07-27T02:39:15+00:00
    even if it were cool to have to switch between sims manually, which is definitely is not. I still can't even find a carrier that supports an esim for this phone????
    what is your problem, go full dual sim
    2021-07-27T05:15:12+00:00
    If you have purchased an unlocked surface duo Att supports esim (my esim has an Att phone number)
    If you bought your phone from Att however the esim will be disabled by Att
    2021-07-27T05:39:29+00:00
    I have an unlocked from from the ms store and att tells me they do not support esim in this phone
    2021-07-27T10:49:32+00:00
    I took mine too the Att store in September 2020 and they activated my esim in minutes.
    I've been using that esim ever since.
    You probably asked someone who was'nt knowledgeable enough to get that done for you.
