Surface Pro Duo Dual SIM
2019-10-04T17:14:57+00:00
We all saw the unveil of the new Surface devices coming soon, right? I feel like the Surface Duo is tailor made for the on the go business professional who really can get everything done from their Surface Duo with its capabilities. The one thing that I'm sure it's missing is Dual SIM capabilities. What do you think? I have multiple phone numbers and carry two phones, both an iPhone Xs Max and Galaxy Note 8. I'd love to downsize that into 1 and have two SIM's in the Surface Duo.
* Moved from Community Participation Center
Surface | Surface Duo | Mobile connectivity
2020-09-28T16:57:07+00:00
Surface Duo has a physical Nano SIM. AT&T locked SKU will have eSIM disabled while the Open market SKU will support Dual SIM single available (physical SIM and eSIM) – so only one SIM for calls, texts, data can be active at one time.
For more information about switching between SIM data plans see, Set up a mobile data connection on Surface Duo.
52 additional answers
    2021-10-29T17:58:38+00:00
    probably not, Att disables the e-sim
    2021-10-29T18:25:32+00:00
    The Duo 2 is a totally unlocked model. The eSIM will work.
    2021-10-31T20:44:51+00:00
    i have an unlocked version. The two questions are A - Will the Duo allow both sims to work simultaneously? B - Will any of the carrier support esims for the Duo?
    2021-10-31T21:17:57+00:00
    The Surface Duo 2 will. The original Surface Duo will not.
