2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-06-05T14:37:03+00:00
    Thanks, this worked.  The key is be patient after detaching.  My device list flicked like 10+ times before settling down.
    One note, while nVidia card is missing, the base runs warm while machine sitting idle.  Normally, it's cold with full productivity work load.
    My guess is that it got lost somewhere between detach hot/cold and sleep/awake.
    4. Unplug your SB2
    2018-06-05T21:37:09+00:00
    We appreciate your patience with regard to the issue. Please monitor this **thread**as we would update the pinned post once a solution is available.
    Should you have other inquiries feel free to post back.
    2018-06-06T00:39:22+00:00
    After about 2 months after I did the hard reset the problem occurred again on my SB2.
    It's been over 6 months since this problem first appeared with thousands of SB owners having the same problem. What it Microsoft taking so long to finally fix this?
