2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-29T01:08:51+00:00
    The first time I had trouble with DGPU detection, I was also having trouble with the latch - I think I started having problems after a firmware update.  I also got the "general failure" error.
    I think a regular restart would sometimes fix the latch problem, but shutdown followed by power up often caused latch instability leading sometimes to a general failure error.  But, when the latch was ok, detaching and then re-attaching would cause the DGPU to me detected only for a few minutes.
    The hard restart fixed both problems until yesterday when the DGPU became undetected until I did another hard restart.
    As long as the tablet was physically attached, I think a hard restart would be able re-initialize everything.
    Did you unplug the SB2 from power before doing the hard restart sequence?
    Regards.
    2018-05-29T01:33:57+00:00
    Yes, I did remove it from power.
    I experimented a little and disabled my intel adapter while my Nvidia GPU was detected. This allowed me to use the tablet normally except the camera did not work and I was unable to detach the tablet at all. I restarted several times and the GPU was always available. I re-enabled the intel driver and so far the nvidia is still working, but I am still unable to detach even after several restarts. I am still in the process of troubleshooting that. I think I have to reset the DTX or something.
    2018-05-29T02:26:36+00:00
    Do you have some apps that default to the Nvidia GPU?  If so, the system may not be letting you detach because it knows there are apps using the DGPU.
    Regards.
