2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-28T23:35:37+00:00
    My SB 2 is currently having this same issue, has there been any update or solution for this problem?
    2018-05-28T23:54:39+00:00
    I saw a news report somewhere that claimed Microsoft had fixed the problem, but I've got all the updates and just experienced the problem for a second time the other day.
    I restored the DGPU by doing the following hard restart sequence:
    1. Shutdown
    2. Unplug surface book 2
    3. Hold volume + button down and then press power button for 30 seconds and then exit
       from UEFI so system will restart. (Note: My system rebooted to UEFI twice because I kept holding both buttons down. I exited when the UEFI was displayed the second time)
    This is the second time I've restored the DGPU using the above steps.  The fix lasted for about a month and a half.
    Regards.
    2018-05-29T00:05:36+00:00
    Thank you. The method you describe is not working for me. This may be unrelated to your specific issue but I think the problem has to do with the latching system rather than the video card drivers. Each time that my DGPU is undetected I notice that my surface thinks that the tablet is detached. Sometimes this results in a "General Failure" with the latching hardware and I have to try and detach the table somehow. If I can successfully get the surface to recognize that the tablet is attached then my DGPU is detected and it works fine but if I try to do the UEFI reset at this point it so far restarts with the hardware failure once again. Does your SB have any similar symptoms?
