2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-28T15:10:18+00:00
    I'm beginning to wonder if this problem is caused by a timing problem (which would help to explain why it has been so difficult to fix).
    Yesterday, I interrupted my surface book's process of locking and putting itself in sleep mode by moving my mouse.  There was a slight pause as it switched from lock screen image back to my desktop.  Then, I heard the dreaded chime indicating that the GPU was no longer detected.
    I checked device manager and sure enough it was gone.  I then checked the event log and found the following entries:
    Surface HotPlug ACPI Notify Error: NotifyCode=82
    Surface Serial Hub Driver get response timeout, CanceledID = 12626, TargetCategory = TCL, CommandID = 10.
    The tablet detach-attach procedure restored the GPU for a few minutes.  When the GPU again disappeared I found a cascade of error messages in the event log beginning with
    and followed by a dozen or more invalid checksum and/or signature failures for the surface serial hub driver.
    I restored the GPU by doing the hard restart sequence (without the GPU being detected):
    1. Shutdown
    2. Unplug surface book 2
    3. Hold volume + button down and then press power button for 30 seconds and then exit
       from UEFI so system will restart. (Note: My system rebooted to UEFI twice because I kept holding both buttons down. I exited when the UEFI was displayed the second time)
    I'm running Windows 1083, build 17134.48.  The last update was about a week ago and my surface book has been shutdown and powered on many times since that last update.
    Regards, jketola
    2018-05-28T16:33:19+00:00
    Do you have this problem again yesterday, after you have fixed this issue by hard restart sometime ago ?
    2018-05-28T16:44:38+00:00
    Yes, the problem re-appeared.  However, the hard restart procedure fixed the GPU detect problem again.
    According to the event log, the system entered standby and then exited because I moved the mouse.  A few minutes later a notification error occurred and DGPU was no longer present.
    Regards.
