2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-25T14:06:05+00:00
    I thought that when the screen was attached, Nvidia GPU picks up the slack for programs like those in Creative Cloud or games. I went to use Photoshop and checked performance setting and noticed Nvidia GPU wasn't being utilized so checked Device Manager to find the discrete card not listed under 'Display Adapters'. I then went online and found: https://answers.microsoft.com/en-us/surface/forum/surfbook2-surfupdate/gpu-not-detected-in-surface-book-2/774e1993-4bd4-4e5b-a0b6-0b3197fedb42
    Followed steps through (had updated to 1803 a couple weeks ago), but couldn't even get the latest Nvidia drivers to install due to it not being recognized. Ran through Surface Diagnostics and downloaded and installed Surface Book 2 Firmware for 1803 (17134.48). Upon doing so and restarting still could not see the GPU under Device Manager.. Continuing with suggestions from forum above, I left Device Manager open, then dettached screen, waited 10 seconds while it refreshed, then reattached and voila, Nvidia device popped up. I then was able to install latest Nvidia driver.... BUT upon restart, I go back into Device Manager and the device is STILL missing...... Have to go through above steps of detaching and reattaching for the device to pop up, and obviously only then able to utilize it in my applications.
    What the heck is going on and why isn't the device automatically available? I am leaving the screen attached so when I turn the thing on, the device should be available.
    I'm assuming this is a firmware / 17134.48 issue, and if so, please patch!
    2018-05-26T02:33:34+00:00
    I had the same issue on the 25th as well. Sounds like some update has caused an issue.
    jketola's guidance worked.
    Oddly. it also fixed a oddity with the connection of my power supply. About the same time as the other issue, the SB2 would not show the little plug symbol on the power task bar icon even though led plug light was lite. Now the plug symbol comes on promptly..
    2018-05-26T16:07:06+00:00
    Hello Justin,
    We appreciate your post. Microsoft is aware of the issue and is working to resolve it as soon as possible. You may send your feedback to Microsoft's Feedback Hub app or upvote a feedback if you find it similar to yours.
    Thank you.
