2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-24T03:05:36+00:00
    Its because they have choosen to cover it up and attempt to resolve it.  This kind of an issue would cause alot of big business sales to stop.  If they dont do the right thing soon.  Its funny how law suits can become so public so quickly.  Class actions have a funny way of doing that especially when letters go out to every single possibly effected user.  That could really be damaging.  Sounds like Microsoft might have a big vested intrest to get this resolved soon or that really sounds bad to investors.
    2018-05-24T08:43:31+00:00
    Same issue here... Unable to solve it. Been troubleshooting some but havent found much.
    Latest Nvidia drivers since today, no difference...
    This is my troubleshooting:
    When detaching the screen on my Surface book 2 (13" 8GB version, GTX 1050) and attach it again the 1050 appears again under "Display Adapters" in Device Manager...
    (The device manager seems to do some kind of update/ refresh every second by some reason)
    But when hitting the latest Nvidia Control panel application the 1050 disappears again... This happens every time.
    Havent been able to use the 1050 for MONTHS now!!!
    I also have the "Surface Detach: Hardware Failure" icon in the Taskbar right lower corner with the red "x" icon...
    2018-05-24T14:16:32+00:00
    I had the same symptoms and used the following procedure to fix the problem:
    1. Do a shutdown and then unplug the power cord.
    2. Do a hard restart by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Hint: Press and hold the volume up button down before pressing down and holding the power button.)
    3. If the UEFI interface is displayed, just exit and let the system restart.
    If this procedure doesn't work, try the second solution (by Philip_Aaron) marked as an answer above.
    Please let us know whether one of these procedures worked (and which one).
    What version of Windows are you running?  (I was on 1709 when the problem appeared and was fixed by the above procedure.  I'm now on 1803 without problems.)
    Regards.
