2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-02-05T00:29:48+00:00
    They had me download the latest firmware update from:
    https://www.microsoft.com/en-us/download/details.aspx?id=56261
    and then reboot twice.
    I then used the dock updater tool from:
    https://www.microsoft.com/en-us/download/details.aspx?id=46703
    which was a bit involved as it has you disconnect/reconnect the dock several times.
    Fixed the problem for me.
    2018-02-09T18:21:50+00:00
    Bump,  any info on this firmware update?
    2018-02-11T18:42:46+00:00
    Same problem here on a SB2 15'' with the 1060,
    It seems like it's the same issue as https://answers.microsoft.com/en-us/surface/forum/surfbook2-surfperf/surface-book-2/c55fb901-ffe1-4198-b397-c8986bee2498 and https://www.reddit.com/r/Surface/comments/7vnwx3/surface_book_2_major_graphics_card_problems/
    I got the laptop replaced at my local Microsoft store two days ago. Unfortunately less than 48h later I had another BSOD about nvlddmkm.sys. Same message as the one I was constantly having before replacing my sb2.
    Here's a list of what I've experienced so far on the previous unit.
    • Surface Detach : Detached while the screen is obviously attached to the base
    • Surface Detach : Hardware failure
    • Nvidia Control Panel disappearing in the desktop context menu
    • dGpu disappearing from the device manager
    • dGpu re-appearing after detaching/re-attaching until next reboot, sleep or BSOD
    • BSOD SYSTEM_THREAD_EXCEPTION_NOT_HANDLED nvlddmkm.sys, usually after re-attaching and having the dGpu magically reappear.This would happen most of the time while using the dGpu but also randomly
    • "Error : Dtx failed to enumerate DGpu" for the SurfaceDtxService in the Event Viewer, usually followed by a "Critical. The system has rebooted without cleanly shutting down first"
    I only experienced the two last one since I received the new unit, but it similar enough to think that it's the same issue.
    And here what I've tried so far on my previous machine without success.
    • Restore point
    • Installing all available update and new firmware
    • Uninstalling recent updates including the security spectre/meltdown one that seem to have cause problem to a lot of users
    • Uninstalling Nvidia drivers with and without DDU
    • Power / Volume button reboot
    • Hard reset / Reinstalling windows
    • Brand new unit
    The fact that most other threads talks about this as a recent problem (after months of working properly) makes me hope of a software issue instead of an hardware defect.
    This is my third SB2 and I would love to not have to get it replaced one more time (the first one had an unrelated issue).
    (Edit: Updated links)
