2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-21T13:04:58+00:00
    The only time the nvidia card shows is when I disconnect and reconnect to base. Then after a few minutes it disappears. I updated all the firmware and graphics drivers to the most current. I was having trouble updating the nvidia card initially as it would not recognize that I even had one (no hardware detected in big red letters). I disabled the default video card and I disconnect the base in the middle of the install and then quickly reconnected it just in time for the install to recognize that I did indeed have the hardware before it left on vacation again, then enabled default card again for other system components to work. I do know that I have covered more ground then most others in this situation and still no cigar. SO I have the latest nvidia drivers, updates, and firmware installed, and guess what? It still does the same thing. I have windows 10 pro w/1060gtx card, version 1803, OS build 17134.48, nvidia card driver 397.64 released on may 9, 2018. And yes I did the 3 step reset more times then I cared, without any improvement in the issue. Yes, I showed hidden devices as well. I do know that most programs I open up on the tablet and reconnect the graphics card still stays on for awhile before shutting off. At any point I open autocad the nvidia card immediately malfunctions and goes bye-bye. IT will not stay on with autocad running under any circumstance. So theres a hard condition trigger in cad that makes the card shut off where as it shuts off by a time trigger in most other instances (it seems like that to me). Any manipulation in a registry value that might keep it from turning off? Also, I do have my hibernation disabled, my pc is either off or on and I have changed the registry to accommodate continued use of Microsoft active sync on windows 10(either of which should not be causing issues with the video card).
    2018-05-21T17:58:19+00:00
    My Nvidia drivers are older than yours, but I'm on the same OS.
    When you did the 3-step hard restart, did you unplug the power cord?  Some user's in another forum mentioned that this made the critical difference.
    Any useful error messages in the event log?
    I'm going to talk to Microsoft on Thursday and will provide an update.
    2018-05-21T19:39:43+00:00
    Philip,
    Do you know whether the GPU stopped being detected after the update titled "3/7/2018 version 4.7.136.0 firmware update" was applied?  (This update is suppose to improve hibernation on Windows 10 April 2018 Update.  Note, the date in the title is likely wrong - it probably should be sometime in May.)
    Regards.
