2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-19T20:58:15+00:00
    same problem hope this gets resolved. I thought my computer had a virus or something. Autocad was running slow, here the dedicated graphics card isn't even recognized or functioning from what I can see. IF this is not resolved I am returning this thing and getting a laptop that doenst have serious issues
    2018-05-19T21:31:05+00:00
    I get that your frustrated.  I would/will be too if it  happened/happens again.  But, can you answer a few questions so others in the forum can anticipate what might happen and why:
    1. I assume you did the hard restart again without success.  Is this true?
    2. What version of Windows are you running?
    3. Are there any entries in the system event log that offer clues to what went wrong?
    4. Did Windows recently install another update?  What was the last update installed?
    I just checked Windows update on my surface book and see that there is a 3/7/2018 update pending.  Did you just get this update?
    Thanks.
    2018-05-19T21:53:33+00:00
    Thanks.
    The pending 3/7/2018 version 4.7.136.0 update is a firmware update that is suppose to improve hibernation on Windows 10 April 2018 Update.
    The last time we had a firmware update, it caused problems with the Nvidia GPU that could be fixed by doing the hard restart procedure.
