2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-19T16:57:27+00:00
    Guess what the Hard Reset with the that clears the display settings is not a solution either.  It just happened to me again today.  I had to remove the tablet from the keyboard and then re-attach it.  It seemed to clear the issue but like before that never worked.  I could do the hard reset again but this now is an issue beyond a simple fix.  There needs to be an official statement and fix on this now!  Its been over 6 months and now its happening again.  Microsoft you are going to get sued.  This is getting beyond a recall of some sort or serious software fix.  I am not going to wait till my warranty is up and then start paying for fixes to a known issue.  I will sue you way before that happens and I am sure by this thread I will have no problem getting people to join my law suit.  Better get your house in order because the poop is about to hit the fan real soon on this issue.  Its time to take this very seriously.  FYI you almost had an Apple customer but now lost me again for several years to come if this is not taken a lot more seriously.  GET YOUR DAMN HOUSE IN ORDER!!!!!  CAN YOU HEAR ME NOW!
    2018-05-19T17:38:41+00:00
    Hi Brandon,
    I'm not sure what procedure you are following when you say you did a "Hard Reset".  However, the following procedure worked for me and for others on this forum:
    1. Do a shutdown and then unplug the power cord.
    2. Do a hard reset (i.e. restart) by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Hint: Press and hold the volume up button down before pressing down and holding the power button.)
    3. When the UEFI interface is displayed, just exit and let the system restart.
    As someone pointed out, this procedure should really be called a "hard restart."
    What version of windows are you running?
    I initially fixed the problem on my surface book using the hard restart while on build 1709.  I'm now on build 1803 and don't have any problems.   In fact, I saw some reports in a couple of technical news articles that say Microsoft has fixed the problem as of build 1803.
    If you have tried the hard restart described above, can you try it again just in case you missed a step?
    Please let us know whether this works.
    I've been asked to fill out a survey for Microsoft support.  It would help to know whether you were able to fix the problem by using the above procedure.  If I get a chance, I will convey your frustration with support.
    2018-05-19T19:54:26+00:00
    I did that all before it worked for about 4 months back then it came again today.  I posted that solution originally.  I was one of the first to figure it out.
    Its only a matter of time till it comes back for you.  Thats why i am so pissed now!
