2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-16T21:44:15+00:00
    I updated to 1803 and it has resolved the issue in my case.  I also did the hard reset before i got the new update.  Just a FYI.
    2018-05-17T02:34:35+00:00
    Hi Madden70.  When did you update?  Ive tried a total re-install and update with no success about a week ago.
    2018-05-17T03:48:56+00:00
    Thanks very much jketola, that seems to have fixed the issue.  I hope this doesn't happen again.  I've wasted weeks trying to resolve this problem instead of working on something productive.
