2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-16T14:21:49+00:00
    Copied from previous replies:
    The following procedure fixed the problem for me and others in this forum:
    1. Do a shutdown and then unplug the power cord.
    2. Do a hard reset by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Hint: Press and hold the volume up button down before pressing down and holding the power button.)
    3. If the UEFI interface is displayed, just exit and let the system restart.
    Please let us know whether this fixed your problem.
    2018-05-16T19:31:47+00:00
    2018-05-16T19:37:49+00:00
    I'm not sure which version of the firmware and drivers you upgraded to, but others in this forum have reported that windows build 1803 fixes the problem.  Also, I've seen news articles stating that Microsoft thinks they have fixed the problem.
    I'm still on build 1709.
