2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-14T04:20:16+00:00
    Thanks, it looks solved the issue after doing the hard reset. I pent a day with my SB2 with no issue.
    2018-05-16T12:36:36+00:00
    "I have the same issue as well.  Plus I cannot turn on my machine until i detach the screen first ..."
    if I click the button and be really patient the surface will show Microsoft office logo and start, I think detaching it is not related, I thought I had this problem and I used to detach it and I get the illusion that detaching fixed it.
    The surface by default settings go to hibernate mode. and it take "FOREVER" for it to show a feed back that it is starting.
    worth double checking it.
    update on my problem:
    windows updated to version 1803 (Build 17134.48) the problem still remain.
    I noticed that even after reattaching the screen if I do not use the GPU for a short amount of time, the GPU will get disconnected/disappear/what-ever-its-called.
    I may be having the same problem as the hundred of posts about the GPU vanishing. and "This is most likely caused by a software problem. Microsoft engineers have been investigating a possible root cause and solution"
    I really hope if Microsoft make the update they make the drivers available on the surface page ,because windows updates for me can be delayed.
    2018-05-16T13:58:19+00:00
    Hi Ruz, it's been 10 days since I posted here with my problem and there is still no solution.  I've found out I can't get my money back so I'm stuck with a device I don't want.  I will be contacting the ACCC to see what I can legally do about this but I find it surprising that most users of the surface book 2 find this acceptable.  Perhaps they're used to issues like this occurring.  I'm not used to paying almost four thousand dollars for a device I can't use.  This will be a lesson for me to never trust Microsoft's Surface Products again.  Months with the same message from this forum and from the Microsoft store is not good enough.  I'm starting to believe this is actually a hardware device and not what we've been told.
