2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-10T15:13:12+00:00
    Hi
    I have the exact same problem, I have a new Surface Book 2 that is supposed to have the NVidia (and had it for some time), but now it can't find it and games runs terrible on the machine.
    Another thing is that the battery holds power for max 3 hours, while browsing IE or writing mails. I switched from having 3 generations of MBPRO and I kind of regret that I did the switch
    2018-05-10T15:15:43+00:00
    I think the new Spring update that came out may have fixed it.  I did a clean install the other day on my machine and after it did the spring update everything was fine and I am running GeForce Experience with the current Nvidia drivers and so far so good.  I will agree with you though...this is a temperamental machine.
    2018-05-10T15:18:21+00:00
    I believe the April 1803 update may have fixed this long ongoing issue.  I did the hard reset fix about a month ago before the update and haven't had the problem since so i dont know if the 1803 fixed it but many say it has.
    The worst part about this is about 75% of folks that have this laptop probably don't even realize they are missing their GPU!
    Microsoft should send out a email to Surface Book 2 owners letting them know the issue and the fix.
