2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-05-08T08:45:08+00:00
    just confirming that since the WINDOWS 10 April Update (to 1803), I have nomore problem with the recognition of the NIVIDIA Board (mine is GTX1050). I installed this update now since more than 1 Week. I am still crossing the fingers.
    I am still waiting a confirmation from Tech Spt that they fixed the problem with their April Update.  I am not 100 pc sure as they talked of a fix in May to you.
    2018-05-08T13:47:16+00:00
    I confirm too: I've installed 1803 update on my Surface Book 2 on last Thursday, by using a "trick" (deleted Provisioning folder and registry entries), and this update solved issue with "disappearing" NVIDIA GPU.
    Also, it looks like Microsoft resolved another issue with cameras (during debugging of UWP app, working with cameras, Surface Book 2 may have some BSODs because of bug in kernel driver).
    2018-05-08T16:23:02+00:00
    Yeah, I ran the tool after the April 2018 update. It is working just well right now, and the task bar icon now shows status and conflites when attempting to remove the clipboard off the base.
    One question that I have is that I'm still trying to get to grips to the performance of the Surface Book, and in a recent test with Team Fortress 2, the game played smoothly over 60FPS in Full HD, but immediately struggled to deal with AI bots. The performance hit was the same for a single and 32 bots. Any reason to why is this the case?
