2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-04-30T18:05:09+00:00
    Ok ready to follow your procedure, but if I am following  your 5 points, do I loose my files and applications after the system restart???? IOW does it apply me to do first a Save All ???
    2018-04-30T19:02:18+00:00
    Marc,
    I was one of the early people to confirm this proccess works.  It will clear out all your custom display driver settings or any saved precerences of how you have multiple displays arranged.  It does not removed any data outside of your display settings.  This is a small pain to put back for the problem it fixes.  Good luck and if you follow the steps yiu will be pleased with the result.  It is a lasting fix to the problem and it will not come back for now unless Microsoft breaks it again.  Cheers!
    2018-05-02T19:48:53+00:00
    My latest experience after installing the windows 10 April update. The base Nvidia card driver will not show up in the device manager using the methods discussed in this forum.  I had to reinstall the Jan 2018 Surface Book 2 driver update bundle from  Microsoft.com, do the hard reset as described in this forum. A new display adapter driver is installed with the update called 3d video controller. After reinstalling the Jan 2018 drivers, this 3d driver is gone.
