2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-04-30T14:20:49+00:00
    Just a small pedantic suggestion. I think we should refer to the process as a "hard restart" which is more accurate.
    A "hard reset" sounds like you're wiping the laptop of everything.
    As Orlando says, we aren't specialists but the suggested process does seem to be working for people here. I did it over a month ago now and haven't had the problem since. If I end up having to hard restart the laptop every couple of months, I can live with that (although obviously it shouldn't be happening in the first place).
    2018-04-30T14:36:22+00:00
    Good point Podsnafu - hard restart is more accurate as we are not wiping any data or software from the device. Much less scary than that!
    2018-04-30T14:46:27+00:00
    Oh and one more point.
    Microsoft are releasing the latest update to Windows 10 today. Whether it contains a fix or not, I strongly suggest waiting until it appears in Windows Update in the Settings app rather than manually downloading the update today.
    MS tend to release updates gradually and sometimes manually updating it will miss some hardware specific additions they might release at the same time.
    From what I've read, the first specific hardware will see of it is next week.
