2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-02-04T22:19:52+00:00
    I have the same issue.  disconnecting and reconnecting the base temporarily allows the NVidia card to be recognized but then disconnects on its own.  many errors showing in event viewer:
    Dtx failed to enumerate DGpu.
    I've done a fresh start twice to no avail.
    2018-02-04T22:29:09+00:00
    Ok I think I have a solution.
    Same as you, disconnecting and reconnecting the base only temporarily fixed the problem, the next reboot the Nvidia card wasn't recognised again.
    So I too did a fresh start ----> no difference (just a big waste of time).
    Then I found out about doing a hard reset by holding down the power button and volume up button for 20 seconds. I think this must clear the nvram/cmos or something because since I did that my Nvidia card is playing nice again and everything is back to normal.
    So I strongly suggest you try that to see if it helps.
    J
    2018-02-04T22:46:15+00:00
    Thanks John,
    I've done the same and it seems to have corrected the problem as well... for now.
    If I recall, it's 30 sec and you get to the EFI screen before releasing (for anyone else with this issue)
    I will update if I continue to see the error.
