2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-04-19T11:28:57+00:00
    Ok, after investigating that a bit more, I have to take my solution back. Its only temporary.
    So the Nvidia card works, until you start an application that needs GPU, then it get disabled. Or if your Surface goes into Sleep it also get disabled.
    Reconnecting the screen, it comes back but with an error.
    Deinstall the driver, then its fixed for another round until it get dropped again.
    So if Microsoft don't fix that soon, I will give the laptop back. Sorry guys, but sucks.
    2018-04-19T11:30:18+00:00
    Try the hard reset solution, it worked for me (so far) :)
    From above:
    1. Do a shutdown and then unplug the power cord.
    2. Do a hard reset by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Hint: Press and hold the volume up button down before pressing down and holding the power button.)
    3. If the UEFI interface is displayed (I can't remember if it was), just exit and let the system restart.
    2018-04-20T16:17:49+00:00
    SOLUTION----
    I ran into the exact same issue after 2 months of a brand F&*(ing new Surface Book 2 15' with GTX 1060. I suspected it was the Nvidia driver that is causing this issue because it only can't detect the gpu after reboot or sleep. I decided to uninstall all the Nvidia driver, and uninstall any driver in "Device Manager". (Right click -> uninstall device). Then restart the computer and let window 10 automatically update the driver.
    Don't touch anything. You will prob need to restart the computer one more time after it finishes installation => voila. No more issue so far knock on wood
