2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
  1. Deleted
    2018-04-17T01:42:12+00:00
    My 1060 GTX doesn't show up.
    Seems to be faded out in the device manager.
    2018-04-17T01:42:59+00:00
    I've tried updating.
    Uninstalling, updating...
    Restarting.
    Not sure what else to do.
