2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-01-29T03:26:54+00:00
    Had the exact same thing happen very recently, the switched my whole unit out for a brand new one, they said they had not heard of the problem but after browsing the forums this seems to be a common problem of SB2 15" owners after a month or so... hope it doesnt happen to my new unit!
    2018-02-03T05:40:52+00:00
    I have exactly the same problem with the SB2 13", the NVidia 1050 has just vanished.
    Do you know where to get this new firmware update (+ dock firmware) that fixed your machine?
    John
    2018-02-03T05:49:01+00:00
    Ha! can answer my own problem.
    Despite multiple reboots/power cycles the system wouldn't find the NVidia card.
    I needed to detach and then reattach the screen to force it to find it!
