2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-04-08T14:02:39+00:00
    I'm not sure what you mean by "having conflict," but I fixed the GPU not detected problem and the latch hardware failure problem (that showed up after the
    update that changed the firmware revision to 388.1932.769.0) with the following procedure:
    1. Do a shutdown and then unplug the power cord.
    2. Do a hard reset by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Hint: Press and hold the volume up button down before pressing down and holding the power button.)
    3. If the UEFI interface is displayed (I can't remember if it was), just exit and let the system restart.
    2018-04-09T08:56:13+00:00
    This forced start/restart works for me too.
    My SB2 has been working (with dGPU) for several days now (including sleep and shutdowns) without dropping the dGPU.
    While MS still need to fix the problem, this is at least comparatively easy to live with (even if I have to do it once a week or whatever it turns out to be).
    Microsoft, please keep us in the loop, even if it is to say you've not found a permanent solution yet.
    2018-04-10T00:34:30+00:00
    I had a similar problem after the update that changed the firmware revision to 388.1932.769.0.
    I fixed the problem by:
    1. Unplug the power cord.
    2. Do a hard reset by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Press and hold the volume up button down before pressing down and holding the power button.)
    I think this works because the UEFI reestablishes the software interfaces with the hardware.  Maybe an engineer from Microsoft can elaborate.
    Thanks for the post, this worked for me.
