2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-04-07T19:08:52+00:00
    I have the 15 inch model w/ GTX 1060 and the instructions in your post worked for me.
    The 1060 has reappeared in task manager and device manager. I will post an update if it disappears again.
    I'd also still like to see an official cause and resolution posted to this thread by Microsoft.
    2018-04-07T20:03:04+00:00
    Same problem here on a SB2 15'' with the 1060,
    It seems like it's the same issue as https://answers.microsoft.com/en-us/surface/forum/surfbook2-surfperf/surface-book-2/c55fb901-ffe1-4198-b397-c8986bee2498 and https://www.reddit.com/r/Surface/comments/7vnwx3/surface_book_2_major_graphics_card_problems/
    I got the laptop replaced at my local Microsoft store two days ago. Unfortunately less than 48h later I had another BSOD about nvlddmkm.sys. Same message as the one I was constantly having before replacing my sb2.
    Here's a list of what I've experienced so far on the previous unit.
    • Surface Detach : Detached while the screen is obviously attached to the base
    • Surface Detach : Hardware failure
    • Nvidia Control Panel disappearing in the desktop context menu
    • dGpu disappearing from the device manager
    • dGpu re-appearing after detaching/re-attaching until next reboot, sleep or BSOD
    • BSOD SYSTEM_THREAD_EXCEPTION_NOT_HANDLED nvlddmkm.sys, usually after re-attaching and having the dGpu magically reappear.This would happen most of the time while using the dGpu but also randomly
    • "Error : Dtx failed to enumerate DGpu" for the SurfaceDtxService in the Event Viewer, usually followed by a "Critical. The system has rebooted without cleanly shutting down first"
    I only experienced the two last one since I received the new unit, but it similar enough to think that it's the same issue.
    And here what I've tried so far on my previous machine without success.
    • Restore point
    • Installing all available update and new firmware
    • Uninstalling recent updates including the security spectre/meltdown one that seem to have cause problem to a lot of users
    • Uninstalling Nvidia drivers with and without DDU
    • Power / Volume button reboot
    • Hard reset / Reinstalling windows
    • Brand new unit
    The fact that most other threads talks about this as a recent problem (after months of working properly) makes me hope of a software issue instead of an hardware defect.
    This is my third SB2 and I would love to not have to get it replaced one more time (the first one had an unrelated issue).
    (Edit: Updated links)
    I had a similar problem after the update that changed the firmware revision to 388.1932.769.0.
    Microsoft support had me reinstall Windows which did not help.
    I fixed the problem by:
    1. Doing a shutdown and then unplugging the power cord.
    2. Doing a hard reset by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Press and hold the volume up button down before pressing down and holding the power button.)
    3. If the UEFI interface is displayed (I can't remember if it was), just exit and let the system restart.
    I think this works because the procedure causes UEFI to reestablish the software interfaces with the hardware.  Maybe an engineer from Microsoft can elaborate.
    I'm pretty confident that it was the firmware update that caused the problem and the two button reset that fixed the problem, because:
    1. After I fixed the GPU and latch problems with the above procedure, I discovered that my system was only up-to-date as of December 2017 because Windows update had failed.
    2. I checked the firmware and it had the same version number and likely had not been updated because of the windows update failure.  You can't undo a firmware update.
    3. The GPU and detach latch continued to work after I used the windows update troubleshooter tool to fix windows update and then install the remaining updates.
    2018-04-08T08:59:15+00:00
    GPU not showing up.. having conflict .. Please advise on how to fix
