2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-04-07T06:20:32+00:00
    Greg,
    Can you provide any update to this issue. I am currently having the same problem as Rajeev, where the Nvidia GeForce 1050 GPU is not showing up at all in device manager, and no other solutions seem to be able to find the GPU. These are $2500+ laptops, supposedly top of the line, that we aren't able to use to their specifications. Transparency on this issue would be much appreciated.
    Taylor
    2018-04-07T17:51:25+00:00
    I had a similar problem after the update that changed the firmware revision to 388.1932.769.0.
    I fixed the problem by:
    1. Unplug the power cord.
    2. Do a hard reset by pressing down both the volume up button and the power button down for 30 seconds (more than 20 may work, but I held them both down for 30).  (Press and hold the volume up button down before pressing down and holding the power button.)
    3. If the UEFI interface is displayed (I can't remember if it was), just exit and let the system restart.
    I think this works because the UEFI reestablishes the software interfaces with the hardware.  Maybe an engineer from Microsoft can elaborate.
    2018-04-07T18:02:28+00:00
    Tommy i did the “Fresh Restart” instructions I posted above.  I highly recomend doing that.  Its worled so far for me.  I have not had to do it again yet.  I think for most this should fix it till what ever caused the issue on the begining happens again.  See one day i opened my SB2 to find an error wity the docking onnthe key board.  However it was not there the last tome i used it.  Ever since that moument is when it started for me.  After following those special restart options it has been fine so far.  It has been a few dats now.
