2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-04-04T05:14:43+00:00
    Having the same issue. My SB2 is less than 2 months old. If I had this issue for the first month, I'd definitely return it. I detach the clipboard and dock on daily basis since I'm a student I need to jot down notes every day.
    I just upgrade the driver to NVIDIA latest one. Microsoft latest firmware didn't install on my device. I think they're up to date already.
    Hope to see a solution.
    2018-04-04T07:48:38+00:00
    I have the same problem... I tried a system reset, but still the dGpu disappears... I'm currently travelling in SE Asia so I don't really have the option of returning it. What can I do?
    2018-04-04T13:48:53+00:00
    Hi Mylesey,
    Based on the information that you have mentioned, it would be best that you contact our Global Customer Support for further assistance.
    Regards.
