2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-03-29T03:25:25+00:00
    Can you post the link for the dock firmware update?
    2018-03-30T14:44:17+00:00
    https://www.microsoft.com/en-us/download/details.aspx?id=56261
    determine if you have 15063 or 16299 in "About my PC"
    2018-03-30T15:01:30+00:00
    Unfortunately this firmware update did not solve my issue. GPU is still missing and unusable.
