2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-03-20T15:21:54+00:00
    Screenshot just taken now:
    I am a professional user of 3D CAD software like Autodesk Revit and AVEVA Everything3D, so it is important to me that the graphics card can cope with this software.
    Could the NVIDIA drivers have been disabled by someone? I did relinquish control of my machine while the Aveva software was being installed.
    I would be keen to get the better graphics card operational. Your help would be much appreciated.
    Best regards,
    Declan
    2018-03-20T16:52:27+00:00
    to everyone trying to trouble shoot:
    both nvidia and MS are well aware of the SB2 driver / GPU issue:
    here's the hotfix from Nvidia:
    https://nvidia.custhelp.com/app/answers/detail/a\_id/4639/~/geforce-hotfix-driver-version-391.05
    2018-03-21T05:10:39+00:00
    I think I find the root of the problem. The latest updates didn`t install the driver of Nvidia graphics card successfully, resulting in the malfunction of Nvidia graphics card. I download the driver on Microsoft official website ( in the "support " sheet ), unzip it and install just Nvidia graphics in that zip file and everything is brought back to normal.
    I think Microsoft should double-check the updates in case of events like that happening again.
    Best wishes.
