2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-03-15T21:33:12+00:00
    System Restore (Fresh Start) / downloading latest firmware fixes the "GPU not detected issue."
    However graphic intensive programs like Adobe illustrator, photoshop or Rhino 6 & 3dsMax still perform poorly due to OEM drivers
    2018-03-15T22:02:56+00:00
    Take a look at the nVidia 391.05 driver. Previous versions didn't work with the Surface Book, but that version explicitly does.
    Note that I did give this driver a shot, and every time my Surface Book 2 lost the nVidia card, Windows would blue screen. I've reverted back to the default driver until a proper fix is out.
    2018-03-15T23:56:05+00:00
    At this point I returned it and repurchased new Surface Book. Don't have problem with new one so far.
