2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-03-14T11:53:03+00:00
    1.Fresh Start twice
    1. Updated to latest firmware
    https://www.microsoft.com/en-us/download/details.aspx?id=49497
    1. Global Setting set to dGPU
    2. Enabled & "Updated" to latest Nvidia driver
    2018-03-14T22:50:43+00:00
    Thank you for the update, Tommy. We already raised this with our internal support team and they are presently communicating the issue with industry partners. An announcement shall be forthcoming soon. We appreciate your patience and cooperation.
    Regards.
    2018-03-15T06:46:01+00:00
    Just wanted to say I have the same exact issue and to think I spent $3400 on a machine I can't use for the sole purposes I bought it for is crazy.  Hopefully the hotfix that Nvidia provides soon will work.  HUGE thank you to original poster for tracking this issue down.
