2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-03-09T00:25:38+00:00
    Thank you for the response. Since your device under warranty. Yes, you can ask for a refund or the best option for your Surface Book 2. Keep us updated.
    Cheers.
    2018-03-10T03:05:08+00:00
    I have to say that I am really disappointed in the SB2.  When the GTX display driver flops, it flops. There is no rhyme or reason for it. Even if I reboot it, it doesn't show up.  Only way I can get the display driver back is by detaching the tablet and re-seating it in the performance base.
    Though I think that the docking station has something to do with it.....updated the firmware for it, but same issue.  Have to see if the GTX drivers flop when it is not connected to the dock.
    Though I want to believe in the Surface Book2, when the GPU display drivers arbitrarily crash when using pro aps, it is infuriating and my fix of unseating from the performance base and reconnecting is just not cutting it. It desperately needs a firmware update.
    Frankly, starting to get buyers remorse, should have gone with the Razerblade.
    2018-03-10T18:42:30+00:00
    yeah, but not only the docks, I think any new plug-in devices may cause the GTX 1060 out of work.
