2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-03-07T01:44:33+00:00
    Hi Andrey,
    Glad you reached out. We are certain that the new driver update that you've downloaded didn't mean any harm to your Surface Book 2. They were made available to solve reported issues, better yet, improve their performance.
    To make the new driver update and its hardware work accordingly, we suggest that you check for and manually install the Surface Book 2 updates, make sure the device has enough power to download and install them. After installing the updates, please restart (not shutdown) your device. Then, open Device Manager to verify that the NVIDIA GPU now appears on the list.
    Here's a link to manually update your Surface Book 2.
    Should the issue still persists, we recommend that you reach out to our Assisted Support here.
    Regards.
    2018-03-08T22:49:17+00:00
    The graphics card on my Surface Book 2 was NVIDIA GE Force GTX 1050, but now it is Intel® UHD Graphics 620. How or why did it change?
  3. Deleted
