2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-03-05T06:48:26+00:00
    I have tried but still failed, I even tried using the surface diagnostic toolkit, installed sb2 driver and firmware (SurfaceBook2_Win10_16299_1801009_0.msi), installed driver from nvidia, reset this pc, and checked for updates (the update I'm using is version final 1709, os build 16299.248 )
    I tried many ways but still failed, gpu still not deteced
    2018-03-05T09:16:17+00:00
    2018-02 Cumulative Update, just noticed that it will not show the dGPU on initial boot but removing slate and reattaching gets it detected.  First cumulative, i have ever seen that now prevents Nvidia's installer from seeing the GTX 1060 in the SB2 for driver updates. wow.
    /golf clap MS thanks..
    Last driver that worked was 390.77.  Guess I will be going to the Store to get one that works...
    2018-03-05T22:48:33+00:00
    Thank you for the update. Since you sort out all the troubleshooting steps that can address the issue and still nothing works. The best option now is to contact our Answer Desk Team or visit the store where you bought your Surface Book 2. That way they can evaluate  your device physically and if they will exchange it to a new one, ask for a refund instead and buy a new one. Make sure to test your device before leaving the store. Let us know the outcome.
    Thanks.
