2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-02-28T18:44:30+00:00
    Hi I've been trying to get some games running on my surface book 2 and realized that they were being run through the integrated graphics and not the 1060 geforce card that comes in the surface book 2. So I tried accessing the nvidia control panel and got an alert that "an nvidia graphics card was not detected in your system". After restarting and having the same issue I tried finding it in my display adapters in the device manager and it wasn't listed there just the integrated Intel graphics. I found it there when I turn on the show hidden devices option but the properties say that the device is not connected to my computer. I have it in laptop mode so the card should be attached. What should I do to fix this issue. I'm hesitant to uninstall the card and I'm not sure how to connect something that should already be connected. Is this a windows issue or is it a hardware malfunction?
    2018-02-28T18:49:57+00:00
    Also when I detach then reattach the screen to the keyboard the Device Manager momentarily detects the nvidia card as being connected and working but in less than 60 seconds the graphics card is unconnected again. I'm sure this is a windows problem now are there any known fixes?
    2018-03-01T17:36:31+00:00
    Hi there,
    I've purchased a new Surface Book 2(GTX 1060) about two months ago.
    Everything seemed to work fine until the GeForce Experience installed a new driver update 391.01. The download was successful, however, the installation was not - due to incompatibility of hardware.  I tried to reinstall drivers manually, which didn't work either. After attempting to reinstall the GeForce Experience I stumbled into a problem, the application prompted a message: NVIDIA Installer cannot continue, NVIDIA GeForce Experience requires an NVIDIA GPU.
    Moreover, the GTX card doesn't seem to show up in the DEVICE MANAGER under the "display adapters" or "other devices" either.  There are a few "unknown devices" in the "other devices" tab though.
    Can you please suggest a solution the above problem? It would be greatly appreciated!
    Andrey
