2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-02-26T20:19:25+00:00
    So I just did a start fresh today to reset my Surface Book 2 because the Xbox One Wireless Controllers were not being detected.
    That issue is fixed, however, this much worse problem has raised its head. My 1060 is being detected sort of, it shows up under device manager, and NVidia control panel. However when I try to install any drivers or if I try to force the 1060 to be used, it does not detect. Simillarly, the system runs all games and programs launched with the integrated graphics. None of them use the GPU itself. I have tried restarts and have installed the Surface Book 2 update packages posted here. Still nothing. Has my Surface **** the bed by doing the "fresh start"?
    Returning is not an option, this is a launch Surface Book 2 15' 1TB.
    Please tell me this awesome device is not ruined...
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2018-02-26T21:36:07+00:00
    you should EXCHANGE it. if you are in the US, go to a physical retail Microsoft
    Store - make an appointment first and confirm they have one in stock. otherwise
    you will need to exchange online.
    2018-02-27T12:15:19+00:00
    I have a Surface Book 2 i7 that I bought at launch last year. In Device Manager, I cannot locate the GPU - specifically, the Nvidia GTX 1050.
    The Nvidia chip was showing as a "hidden" device which wasn't working, so - following an FAQ - I uninstalled it in order to get Windows to reinstall the appropriate software to get it running again. It didn't work. Now the device is not showing at all, any attempt to download or install software/drivers tells me the device doesn't exist, and no matter how many times I scan for the hardware it's not there. All I have is the integrated Intel chip.
    Short of either resetting the machine to factory settings (I don't have a System Restore point created) or sending it back to Microsoft, is there a way to get Windows to add new hardware or force it to reinstall it in Device Manager?
    Thanks.
    Moved from: Windows / Windows 10 / Devices & drivers
