2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
  1. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2018-02-24T10:58:16+00:00
    if it were me, I'd return it for full refund and repurchase.
    >I still have 30 days to return it, not sure if I have to do it now
    2018-02-25T12:18:07+00:00
    Thanks John,
    I've done the same and it seems to have corrected the problem as well... for now.
    If I recall, it's 30 sec and you get to the EFI screen before releasing (for anyone else with this issue)
    I will update if I continue to see the error.
    So far this had fixed mine as well. Greatly appreciate the find, sb2 was less than 2 months old.
    2018-02-25T15:35:56+00:00
    At the MS Store, they replaced for a new one.
