2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-02-22T16:10:37+00:00
    Shocking!
    Mine does not.
    2018-02-22T20:34:13+00:00
    Thanks all for your feedback and support.
    Now that many are having the same issue. I hope this is a software issue which shall be fixed via an update from Microsoft.
    It's frustrating though. Took me 6 years to run into my first issue with my Apple MBP. Now switching to Windows, I run into this issue less than a couple of months from my purchase date.
    2018-02-23T21:49:15+00:00
    I have similar issue, and it's got resolved if I detach and reattach keyboard 3 times. Read about it somewhere, and it worked for me.
    But then it happens again. I didn't figure out pattern yet. I use dock with second monitor, might be related to attaching to dock.
    I still have 30 days to return it, not sure if I have to do it now?
