2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-10-23T05:37:48+00:00
    ...for all the customers experiencing issues with their surface books and surface tablets here some good news (I know you have been waiting for it): according to this article:
      ...https://www.computerworld.com/article/3215089/microsoft-windows/microsoft-surface-reliability-problem-its-more-than-hardware-and-software.html
    we are not alone - indeed 25% (yes, 1 quarter!!!!) of the buyers experience issues with these top-end devices. So for all people still without these shiny MS products, who have money (a lot of money) and time (a lot of time) on their hands,  and (most important!) don't need these devices for work: go for it and join the club of unpaid trouble-shooters and testers and you will be rewarded with  a boredom free life…(well, not all, 75% - the lucky ones - might just get a device that does what it should).
    2018-10-23T16:18:34+00:00
    If it helps: I manually installed the GeForce Experience thing and forced the newest driver to re-install the instant I noticed the disconnection. Haven't had the issue since then, which was a few days ago.
    Of course, first you'll need to go around some places where casual users shouldn't even be tempted to go to, least of all to fix issues like these.
    The fix is up there^^. If that doesn't work mid-way or the first time, re-try a few times. If it doesn't work, then your machine is busted, and unless you can replace or return it for refunds, that's at least 2 grand down the drain.
    2018-10-23T19:28:10+00:00
    Hey, they fixed this problem! The solution is, they will give you a new SB2 Laptop. Apparently the first batches of SB2's had a firmware/hardware issue that not you nor a Microsoft software update can fix.
    I walked into a Microsoft store for my scheduled appointment, the tech took one look at it and gave me a brand new SB2 seriously in less than 15 minutes. Thing is they know they messed up and will do you right as long as within the warranty period (I just bought mines for 3k about 2.5 weeks ago).
    So far this new SB2 has no problems. I detach/re-attach and do software updates with no issues (only been a week so holding my breath lol). I think they should put out a press release already and tell all the early adopters we're sorry bring it back and we'll make it right! Thing is they have already acknowledged this privately, they just won't do it publicly of course who would? Hopefully you get this sorted out :) I'm enjoying the newer SB2 they swapped out with me with no issues so far. GL.
