2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-10-22T15:54:48+00:00
    I have the same issue. It's really annoying. We paid good money for a laptop that we expect to work, yet we have to deal with issues like these. I use this laptop for school and to do a little gaming. The only reason I bought the Surface with the GPU is to play just one game, and that game would just shut off and take me to the desktop screen because it cannot read my GPU. I took it to the Microsoft store and they supposedly updated everything so it "should work now" according to the person that was assisting me. He states "If any more problems occur, you can take it to the Microsoft store at the Cerritos Mall." It's like he expected it to get messed up again. I took it back home and was able to play a game for a bit, and then the game shut off on me again because my GPU was not reading. I just want to know if I have to replace my laptop because it seems like this is a common thing for us Surface Book users.
    2018-10-22T22:55:35+00:00
    I ended up returning it and getting something else. There are better less faulty machines out there for better prices..
    2018-10-23T04:47:56+00:00
    How did you return it? Was it in 30 days? I cannot return it and they keep sending me new machines
