2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-02-22T14:06:00+00:00
    How do I update it
    2018-02-22T14:11:11+00:00
    My device have an electric leakage on the keyboard, how about you? (sb2, 13', i7, ram8, ssd256)
    2018-02-22T16:09:38+00:00
    From Settings\Update and Security click View Update History. Then you can click Uninstall Updates.
