2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-10-19T17:18:57+00:00
    Oh, I already updated the drivers manually (Nvidia included), but the real question is how long that fix will last?
    Don't mean how long til the issue apears again, but how long til this method and hard resets stop being useful.
    For a 2000+ machine, that is some good quality, Microsoft.
    2018-10-19T18:50:24+00:00
    Thanks for the detailed analysis Steven, I'm definitely going to try this tonight!
    Also, have you had it where you restart the computer or maybe even during some install process where it automatically restarts the computer but instead of restarting it just shuts down completely. Or hangs with a black screen and doesn't do anything? That's happened more than a few times to me when installing stuff and rebooting.
    Hopefully its just all software related and eventually patched up. I hate to admit it, but I'm kind of missing OSX High Sierra right now just a tiny bit. Good luck to all us SurfaceBook2 users!
    2018-10-22T06:52:43+00:00
    This was reported in July. What is the status of this problem? Considering returing the laptop because of this.
