2018-01-26T04:42:59+00:00
Hello MS support,
Rajeev
2018-05-21T18:09:16+00:00
Hi Robert_at_lane,
  4. Unplug your SB2
Best regards.
2018-03-19T23:28:32+00:00
495 additional answers
    2018-10-11T05:50:49+00:00
    Check your batteries.  My smaller one in tablet section is already down 35% in max charge in less than 1 year.  Go to Command Prompt and type
    powercfg / batteryreport
    This will save an html file for you to review the report.
    Battery 1 = 18,000 mWh
    My Max Charge = 13,470 mWh
    Microsoft told me its not replaceable so they have to exchange the whole machine.  Obviously its not easy to migrate to a new windows machine for a personal machine.  Plus any serives or software costs money.  I find the lack of replacement of the battiers to be very troubling and what happens when I am out of warranty?  What is the cost then?
    2018-10-11T08:25:16+00:00
    @NumbCrib did you ever try the hard restart (only takes a couple of minutes)?
    This seems to consistently fix the problem for most, the fix is temporary but lasts a few months.
    I understand the frustration and I'm not excusing Microsoft but a 2 minute restart every few months is hardly the end of the world.
    2018-10-11T13:43:31+00:00
    OK, big mistake on my part.  Turns out that I purchased the i5 model which does NOT include the dGPU GTX 1050.  This explains why it never appeared under Device Manager.
